Swazi Phil
Hi guys.
So I have a 2013 KTM 300 xcw.
It seems to just dies after 5 mins after starting.. just bogs down like its running out of fuel.
some history, I have had the bike since 2013 with very little trouble, Engine had a full rebuild about 20hrs, ago it probably didn't need it but I felt it was time in order to keep it fresh. Bike was completely stripped and frame powder coated ect. Stator was re-wired due to it not charging the battery, and a new regulator put in.
Since the rebuild it has been running like dream, I noticed coolant in the oil at the last oil change so changed the water pump seal and its fixed that.
Now to the problem I'm having.
Starts right up when cold, I don't usually idle it for long on the choke usually cruise around gently to warm it up, once warm it just dies... and wont restart from electric start or kicking until it cools down. (5 - 10 mins later)
Started by changing the spark plug, started right up again for about 5mins then dies again. checked new plug is burning the right colour.
Cleaned the carb, it looked clean, made no difference. Air filter is clean, I have not changed the spark plug type / number, have not used a different two stroke oil or ratio. I borrowed an ignition coil from another bike to test if it was that it still does it. I have checked fuses, and all electrical plugs to see if they all in properly and seems they are fine, battery is newish and has good charge,
Next I will try running it until it dies and then check for spark to see if its fuel or electrical.
Any Ideas?
Thanks in Advance.
P.S pushing a bike home is great fitness
Phil
Any Ideas?
Thanks in Advance.
Phil
