You get valves, timing chains and the stigma that you are a porker.For 3K more though......... P
Yes, but once it stretches/breaks you will need a second and third one. And so forth.....Just the one timing chain actually.
Braaaap is the sound associated with 2 cycle engines...For 3K more though......... BRAAAAAAAAAAP
Louis
Ek wys sommer net dat ek kon n nuwe bike koop eerder as om by n reputable ou n "80 ure" bike te koop wat my dan n klomp geld kos 20 ure later![]()
Which is why I said BRAAAAAAAAAAAAPBraaaap is the sound associated with 2 cycle engines...
Only if you add a CR250R exhaust onto a 230F.... shabstaBraaaap is the sound associated with 2 cycle engines...
@red_eye_righley have you seen what ive done to my 300?Only if you add a CR250R exhaust onto a 230F.... @shabsta
Ring ting ting at idle... Braaaaap on the pipe.to be fair to marky mark... 2T is generally "Ring ting tingggg", and 4T is "Braaaaap"![]()
Yes, you basically converted it to a Mardi Gras float for gay pride. Look, subsequent to the Orlando ordeal, I completely support your decision.@red_eye_righley have you seen what ive done to my 300?
