2020 Husqvarna FE 350s Dyno Test
Husqvarna’s 350cc four-stroke dual sport model—the FE 350s—enjoys a plethora of updates for 2020. Engine-wise, that includes a lighter cylinder head, new camshafts with revised timing, and a new head gasket that increases the compression ratio from 12.3:1 to 13.5:1.
Eager to see how these changes affected the FE 350s’ performance, we ran it on our rear-wheel dyno to determine peak output. We documented 32.8 hp at 10,100 rpm and 20.5 pound-feet of torque at 7,600 rpm.
Related: How Much Power Does The 2020 Husqvarna FE 501s Make?
2020 Husqvarna FE 350s Dyno Chart
2020 Husqvarna FE 350s Dyno Chart (Robert Martin/)
Engine Specifications
TypeLiquid-cooled, DOHC, four-stroke single-cylinder; 4 valves/cyl.
Bore x Stroke88.0 x 57.5mm
Displacement349.7cc
Compression Ratio13.5:1
Fuel DeliveryElectronic fuel injection
