Saw this today.
BULL
The Blue Puta
In a mate's bike shop.
BULL
The Blue Puta
The split-single system sends the intake fuel-air mixture up one bore to the combustion chamber, sweeping the exhaust gases down the other bore and out of the exposed exhaust port.[1]
The rationale of the split-single two-stroke is that, compared to a standard two-stroke single, it can give better exhaust scavenging while minimising the loss of unburnt fresh fuel/air charge through the exhaust port. As a consequence, a split-single engine can deliver better economy, and may run better at small throttle openings.
A disadvantage of the split-single is that, for only a marginal improvement over a standard two-stroke single, the "Twingle" has a heavier and costlier engine. Since a manufacturer could produce a standard twin-cylinder two-stroke at an equivalent cost to a Twingle, it was perhaps inevitable that the latter should become extinct.[2]
There have been "single" (i.e. twin-bore) and "twin" (i.e. four-bore) models.[3] Unusually for a motorcycle engine, some Twingles have the carburettor mounted on the front of the engine, beneath the exhaust.
Bruno1969
Probably a Puch. Two pistons with y shaped con rod
Another famous Austrian bike!
Pom17
I like trying to get my 4T to lift the front. Soon
Awesome, thanks for sharing
FHM_V
Howzit guys... been a while.... That's wierd, and interesting at what engineers tried in those days....
I is called a Split-Single (as BULL indicated) that is a twin-piston setup that shares a single combustion chamber. This specific example is a Puch Doppelkolben - 250cc. You will see that both the exhaust ports as well as the carb is front facing, that should makes this a post-war model.
Buff
CT
Twice as much shit to go wrong :icon_e_surprised:
