Think I popped a head gasket...
Rooster
Astrids Bizatch
350 ktm with plenty hours, 260
Ok, so fan fuse went at Arrows and I nursed it home...
Now on idle after about 2 minutes it spits coolant from the overflow - if I run it with the cap off it bubbles like mad...
No oil in water or milk in oil.
I've been given an estimate of 4 - 5 k to fix it, sounds a bit heavy.
Any way to make sure it's the gasket before I open it? Other ideas?
Ringo
Reading the subject line, i hope your bikes gasket is ok...?:icon_cry:
fubar
Drain the coolant, refill with water, remove cap and idle until you observe bubbles, place nose near bubbles and if they smell of exhaust gases you have a blown head gasket,alternatively smell the radiator cap. Do the repair yourself for a fraction of the cost.
Rooster
Astrids Bizatch
No, that's the whole job. Gasket is 650.
Shawn
If the bike overheated and it caused the gasket to go then there is a chance the head is warped and will need skimming.
Get a manual and strip it and get the head checked, not a difficult job.
FHM_V
Got a quote from rad for 3k
3k Ain't bad if you're a lazy bugger! But DIY and its going to cost you 650 and some beers, I guess. Ell, I wouldn't mind giving you a hand if I'm available on the day you choose to do it. Plus, its a bonus to you, coz I don't drink...(Crap, I'll probably be doing all the work then, Lol) Rooster
BigMike
Medium Mike
Johannesburg
3k Ain't bad if you're a lazy bugger! But DIY and its going to cost you 650 and some beers, I guess. Ell, I wouldn't mind giving you a hand if I'm available on the day you choose to do it. Plus, its a bonus to you, coz I don't drink...(Crap, I'll probably be doing all the work then, Lol) @Rooster
neither does he ... the coke will be flowing plenty.
