LoopSoosStroop
- Joined
- Apr 3, 2014
- Messages
- 432
- Reaction score
- 0
I've been looking at the specs online.
Except if they made mistakes online the following specs are the same for all of these:
Suspension travel Front 300 mm
Suspension travel Rear 335 mm
Brake discs - diameter Front 260 mm
Brake discs - diameter Rear 220 mm
Steering head angle 63.5°
Wheelbase 1,482±10 mm
Ground clearance, unloaded 345 mm
Seat height, unloaded 970 mm
The only other difference besides the engine capacity is weight without fuel;
250: 107 kg
350: 107 kg
450: 111 kg
500: 111.5 kg
So if you take a 450 or 500 instead of a 250/350 you only have to lug 4 more kg's around, which may or may not make a difference in Roof style riding.
For me personally, it then makes absolutely no sense taking a 250 over a 350, and a 450 over a 500?
And if you are not on a 2-stroke, where the real weight savings are anyway, you might as well get a 500 and be done with it?
Makes me think this is all a big marketing ploy to sell more bikes, having all these models which are so similar anyway?
Thoughts?
250: 107 kg
350: 107 kg
450: 111 kg
500: 111.5 kg
Thoughts?
